Abstract : Enabling high-level programming models on grids is today a major challenge. A way to achieve this goal relies on the use of environments able to transparently and automatically provide adequate support for low-level, grid-specific issues (fault tolerance, scalability, etc.). This paper discusses the above approach when applied to grid data management. As a case study, we propose a 2-tier software architecture that supports transparent, fault-tolerant, grid-level data sharing in the ASSIST programming environment (University of Pisa), based on the JuxMem grid data sharing service (INRIA Rennes).
