YASS: enhancing the sensitivity of DNA similarity search. - Archive ouverte HAL Access content directly
Journal Articles Nucleic Acids Research Year : 2005
(1) , (1)
1
YASS is a DNA local alignment tool based on an efficient and sensitive filtering algorithm. It applies transition-constrained seeds to specify the most probable conserved motifs between homologous sequences, combined with a flexible hit criterion used to identify groups of seeds that are likely to exhibit significant alignments. A web interface (http://www.loria.fr/projects/YASS/) is available to upload input sequences in fasta format, query the program and visualize the results obtained in several forms (dot-plot, tabular output and others). A standalone version is available for download from the web page.
Dates and versions
inria-00448742 , version 1 (25-01-2010)
Identifiers
Cite
Laurent Noé, Gregory Kucherov. YASS: enhancing the sensitivity of DNA similarity search.. Nucleic Acids Research, 2005, 33 (Web Server issue), pp.W540-W543. ⟨10.1093/nar/gki478⟩. ⟨inria-00448742⟩
129 View
0 Download
Share
