OSA: an Integration Platform for Component-Based Simulation
Many discrete-event simulators are developed concurrently, but with identical or similar purpose. This poster presents the Open Simulation Architecture (OSA), a discrete-event component-based simulation platform whose goal is to favor the reuse and integration of simulation software components and models. To favor reuse, OSA uses a layered approach to combine the modeling, simulation, and related concerns, such as instrumentation or deployment. OSA is both a testbed for experimenting new simulation techniques and a tool for real case studies. The ability of OSA to support challenging studies is illustrated by a Peer-to-peer system case study involving millions of components.
Modélisation et simulation
document.pdf (103.72 Ko)
Télécharger le fichier
posterST093rc21.pdf (517.65 Ko)
Format : Autre
