Journal articles
ACCURACY EVALUATION OF FIXED-POINT BASED LMS ALGORITHM
Abstract : The implementation of adaptive filters with fixed-point arithmetic requires computation quality evaluation. The accuracy may be determined by computing the global quantization noise power at the system output. In this paper, a new model for evaluating analytically the global noise power in LMS-based algorithms is presented. Thus, the model is developed for LMS and NLMS algorithms. The accuracy of our model is analyzed by simulations.
Complete list of metadata
https://hal.inria.fr/inria-00450935
Contributor : Romuald Rocher Connect in order to contact the contributor
Submitted on : Wednesday, January 27, 2010 - 4:40:55 PM
Last modification on : Thursday, January 20, 2022 - 4:19:59 PM
Identifiers
  • HAL Id : inria-00450935, version 1
Citation
Romuald Rocher, Daniel Ménard, Olivier Sentieys, Pascal Scalart. ACCURACY EVALUATION OF FIXED-POINT BASED LMS ALGORITHM. Digital Signal Processing, Elsevier, 2010. ⟨inria-00450935⟩
Share
Metrics
Les métriques sont temporairement indisponibles
