Low distorsion decoupled crosstalk resistant adaptive noise canceller - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper addresses the problem of adaptive noise cancelling with low signal-distortion. The proposed canceller consists in adding an adaptive decoupling filter to the well-known crosstalk resistant adaptive noise canceller (CTRANC) while maintaining the benefits of the cross-coupled structure. It uses a new cross-coupled structure named decoupled CTRANC (DCTRANC) suitable for situations where the noise reference sensor is closely spaced relative to the primary one. This method is analyzed and results are given in voice communication context.
Fichier non déposé
inria-00451048 , version 1 (28-01-2010)
  • HAL Id : inria-00451048 , version 1
Ludovick Lepauloux, Pascal Scalart, Claude Marro. Low distorsion decoupled crosstalk resistant adaptive noise canceller. 11th IEEE International Workshop on Acoustic Echo and Noise Control, Sep 2008, Seattle, United States. ⟨inria-00451048⟩
168 Consultations
0 Téléchargements
