Book sections
Global solutions to rough differential equations with unbounded vector fields
Antoine Lejay 1, 2
1 TOSCA - TO Simulate and CAlibrate stochastic models
CRISAM - Inria Sophia Antipolis - Méditerranée , IECL - Institut Élie Cartan de Lorraine : UMR7502
Abstract : We give a sufficient condition to ensure the global existence of a solution to a rough differential equation whose vector field has a linear growth. This condition is slightly weaker than the ones already given and may be used for geometric as well as non-geometric rough paths with values in any suitable (finite or infinite dimensional) space. For this, we study the properties the Euler scheme as done in the work of A.M. Davie.
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/inria-00451193
Contributor : Antoine Lejay Connect in order to contact the contributor
Submitted on : Wednesday, August 22, 2012 - 9:02:37 PM
Last modification on : Thursday, January 20, 2022 - 5:27:05 PM
Long-term archiving on: : Friday, December 16, 2016 - 7:47:02 AM
File
simple_rough_diff_eq.pdf
Identifiers
Collections
Citation
Antoine Lejay. Global solutions to rough differential equations with unbounded vector fields. Catherine Donati-Martin and Antoine Lejay and Alain Rouault. Séminaire de Probabilités XLIV, 2046, Springer, pp.215-246, 2012, Lecture Notes in Mathemics, 978-3-642-27460-2. ⟨10.1007/978-3-642-27461-9_11⟩. ⟨inria-00451193v3⟩
Share
Metrics
Record views
182
Files downloads
582
