Designing domain-specific processors, Proceedings of the ninth international symposium on Hardware/software codesign , CODES '01, pp.61-66, 2001. ,
DOI : 10.1145/371636.371677
Automatic application-specific instructionset extensions under microarchitectural constraints, 40th Design Automation Conference, 2003. ,
DOI : 10.1145/775832.775897
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1.2401
ISEGEN: Generation of High-Quality Instruction Set Extensions by Iterative Improvement, Design, Automation and Test in Europe, 2005. ,
DOI : 10.1109/DATE.2005.191
URL : https://hal.archives-ouvertes.fr/hal-00181685
Processor acceleration through automated instruction set customization, 22nd Digital Avionics Systems Conference. Proceedings (Cat. No.03CH37449), 2003. ,
DOI : 10.1109/MICRO.2003.1253189
URL : http://cccp.eecs.umich.edu/papers/ntclark-micro03.pdf
Mapping applications to a coarse-grained reconfigurable architecture, 2006. ,
A graph covering algorithm for a coarse grain reconfigurable system, Languages, Compilers, and Tools for Embedded Systems (LCTES'03), 2003. ,
Instruction generation for hybrid reconfigurable systems, ACM Trans. Des. Autom. Electron. Syst, vol.7, issue.4, 2002. ,
DOI : 10.1145/605440.605446
URL : http://beijing.cs.ucla.edu/~kastner/papers/iccad01-instruction_generation-extended.pdf
Constraints-driven scheduling and resource assignment, ACM Transactions on Design Automation of Electronic Systems, vol.8, issue.3, pp.355-383, 2003. ,
DOI : 10.1145/785411.785416
MediaBench: A tool for evaluating and synthesizing multimedia and communicatons systems, International Symposium on Microarchitecture, pp.330-335, 1997. ,
A design flow for configurable embedded processors based on optimized instruction set extension synthesis, Proceedings of the Design Automation & Test in Europe Conference, 2006. ,
DOI : 10.1109/DATE.2006.243972
Automatic instruction set extension and utilization for embedded processors, Proceedings IEEE International Conference on Application-Specific Systems, Architectures, and Processors. ASAP 2003, 2003. ,
DOI : 10.1109/ASAP.2003.1212834
System level partitioning for programmable platforms using the ant colony optimization, International Workshop on Logic & Synthesis, 2004. ,
Computation patterns identification for instruction set extensions implemented as reconfigurable hardware, The International Conference on Engineering of Reconfigurable Systems and Algorithms, 2007. ,
Identification of Application Specific Instructions Based on Sub-Graph Isomorphism Constraints, 2007 IEEE International Conf. on Application-specific Systems, Architectures and Processors (ASAP), 2007. ,
DOI : 10.1109/ASAP.2007.4430001
UPaK: Abstract unified pattern based synthesis kernel for hardware and software systems, Materials of the University Booth at DATE 2007, 2007. ,
