Optimization of Routing and Reconfiguration Overhead in Programmable Processor Array Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper, we present a constraint programming-based approach for optimization of routing and reconfiguration overhead for a class of reconfigurable processor array architectures called weakly programmable. For a given set of different algorithms the execution of which is supposed to be switched upon request at run-time, we provide static solutions for optimal routing of data between processor elements as well as for minimization of the routing area and the reconfiguration overhead when switching between the execution of these algorithms. Our experiments confirm that our method can minimize routing overhead and reduce reconfiguration time significantly.
Fichier non déposé
inria-00451676 , version 1 (29-01-2010)
Christophe Wolinski, Krzysztof Kuchcinski, Jürgen Teich, Frank Hannig. Optimization of Routing and Reconfiguration Overhead in Programmable Processor Array Architectures. 16th International Symposium on Field-Programmable Custom Computing Machines (FCCM 2008), Apr 2008, Palo Alto, United States. pp.306-309, ⟨10.1109/FCCM.2008.16⟩. ⟨inria-00451676⟩
109 Consultations
0 Téléchargements
