New interface
Conference papers
Bulk Synchronous Parallel ML with Exceptions
Louis Gesbert 1 Frédéric Gava 1 Frédéric Loulergue 2 Frédéric Dabrowski 3
3 MIMOSA - Migration and mobility : semantics and applications
CRISAM - Inria Sophia Antipolis - Méditerranée , Université de Provence - Aix-Marseille 1, Mines Paris - PSL (École nationale supérieure des mines de Paris)
Abstract : Bulk Synchronous Parallel ML is a high-level language for programming parallel algorithms. Building upon OCaml and using the BSP model, it provides a safe setting for their implementation, avoiding concurrency related problems (deadlocks, indeterminism). Only a limited set of the features of OCaml can be used in BSML to respect its safety: this paper describes a way to add exception handling to this set by extending and adapting OCaml's exceptions. The behaviour of these new exceptions and the syntactic constructs to handle them, together with their implementation, are described in detail, and results over an example are given.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00452559
Contributor : Frédéric Loulergue Connect in order to contact the contributor
Submitted on : Tuesday, February 2, 2010 - 4:10:17 PM
Last modification on : Tuesday, October 25, 2022 - 4:18:27 PM
Identifiers
Citation
Louis Gesbert, Frédéric Gava, Frédéric Loulergue, Frédéric Dabrowski. Bulk Synchronous Parallel ML with Exceptions. Distributed and Parallel Systems (DAPSYS 2006), Sep 2006, Innsbruck, Austria. pp.33-42, ⟨10.1007/978-0-387-69858-8_4⟩. ⟨inria-00452559⟩
Share
Metrics
Record views
175
