Ensuring Lexicographic-Positive Data Dependence Graphs in the SIRA Framework
Usual cyclic scheduling problems, such as software pipelining, deal with precedence constraints having non-negative latencies. This seems a natural way for modelling scheduling problems, since instructions delays are generally non-negative quantities. However, in some cases, we need to consider edges latencies that do not only model instructions latencies, but model other precedence constraints. For instance in register optimisation problems, a generic machine model can allow considering access delays into/from registers (VLIW, EPIC, DSP). In this case, edge latencies may be non-positive leading to a difficult scheduling problem in presence of resources constraints. This research report studies the problem of cyclic instruction scheduling with register requirement minimisation (without resources constraints). We show that pre-conditioning a data dependence graph (DDG) to satisfy register constraints before software pipelining under resources constraint s may create cycles with non-positive distances, resulted from the acceptance of non-positive edges latencies. Such DDG is called {\it non lexicographic positive} because it does not define a to pological sort between the instructions instances: in other words, its full unrolling does not define an acyclic graph. As a compiler construction strategy, we cannot allow thecreation of cycles with non-positive di stances during the compilation flow, because non lexicographic positive DDG does not guarantee the existence of a valid instruction schedule under resource constraints. This research report examines two strategies to avoid the creation of these problematic DDG cycles. A first strategy is reactive, it tolerates the creation of non-positive cycles in a first step, and if detected in a further check step, makes a backtrack to eliminate them. A second strategy is proactive, it prevents the creation of non-positive cycles in the DDG during the register minimisation process. Our extensive experiments on FFMPEG, MEDIABENCH, SPEC2000 and SPEC2006 benchmarks show that the reactive strategy is faster and works well in practice, but may require more registers than the proactive strategy. Consequently, the reactive strategy is a suitable working solution for compilation if the number of available architectural registers is already fixed and register minimisation is not necessary (just consume less registers than the available capacity). However, the proactive strategy, while more time consuming, is a better alternative for register requirement minimisation: this may be the case when dealing with reconfigurable architectures, i.e. when the nu mber of available architectural registers is defined posterior to the compilation of the application.
main_report_negcycle.pdf (24.32 Mo)
Télécharger le fichier
SIRAlib-1.5.tar.bz2 (135.43 Ko)
experimental_results.tar.bz2 (13.1 Mo)
Format : Autre
Format : Autre
