Conference papers
The Traveling Salesman Problem Under Squared Euclidean Distances
Abstract : Let $P$ be a set of points in $\mathbb{R}^d$, and let $\alpha \ge 1$ be a real number. We define the distance between two points $p,q\in P$ as $|pq|^{\alpha}$, where $|pq|$ denotes the standard Euclidean distance between $p$ and $q$. We denote the traveling salesman problem under this distance function by TSP($d,\alpha$). We design a 5-approximation algorithm for TSP(2,2) and generalize this result to obtain an approximation factor of $3^{\alpha-1}+\sqrt{6}^{\alpha}/3$ for $d=2$ and all $\alpha\ge2$. We also study the variant Rev-TSP of the problem where the traveling salesman is allowed to revisit points. We present a polynomial-time approximation scheme for Rev-TSP$(2,\alpha)$ with $\alpha\ge2$, and we show that Rev-TSP$(d, \alpha)$ is APX-hard if $d\ge3$ and $\alpha>1$. The APX-hardness proof carries over to TSP$(d, \alpha)$ for the same parameter ranges.
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/inria-00455193
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, February 9, 2010 - 4:48:49 PM
Last modification on : Friday, September 17, 2021 - 2:50:09 PM
Long-term archiving on: : Friday, June 18, 2010 - 6:10:21 PM
File
deberg.pdf
Identifiers
  • HAL Id : inria-00455193, version 1
Collections
Citation
Mark de Berg, Fred van Nijnatten, Rene Sitters, Gerhard J. Woeginger, Alexander Wolff. The Traveling Salesman Problem Under Squared Euclidean Distances. 27th International Symposium on Theoretical Aspects of Computer Science - STACS 2010, Inria Nancy Grand Est & Loria, Mar 2010, Nancy, France. pp.239-250. ⟨inria-00455193⟩
Share
Metrics
Record views
89
Files downloads
874
