Dispersion in unit disks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present two new approximation algorithms with (improved) constant ratios for selecting $n$ points in $n$ unit disks such that the minimum pairwise distance among the points is maximized. (I) A very simple $O(n \log{n})$-time algorithm with ratio 0.5110 for disjoint unit disks. In combination with an algorithm of Cabello \cite{Ca07}, it yields a $O(n^2)$-time algorithm with ratio of 0.4487 for dispersion in $n$ not necessarily disjoint unit disks. (II) A more sophisticated LP-based algorithm with ratio 0.6495 for disjoint unit disks that uses a linear number of variables and constraints, and runs in polynomial time. The algorithm introduces a novel technique which combines linear programming and projections for approximating distances. The previous best approximation ratio for disjoint unit disks was 1/2. Our results give a partial answer to an open question raised by Cabello \cite{Ca07}, who asked whether 1/2 could be improved.
dumitrescu.pdf (216.53 Ko) Télécharger le fichier
inria-00455298 , version 1 (10-02-2010)
  • HAL Id : inria-00455298 , version 1
Adrian Dumitrescu, Minghui Jiang. Dispersion in unit disks. 27th International Symposium on Theoretical Aspects of Computer Science - STACS 2010, Inria Nancy Grand Est & Loria, Mar 2010, Nancy, France. pp.299-310. ⟨inria-00455298⟩
Collections
STACS2010 TDS-MACS
85 Consultations
198 Téléchargements
