Correlation clustering, Machine Learning, pp.89-113, 2004. ,
Treewidth: Characterizations, Applications, and Computations, WG, pp.1-14, 2006. ,
DOI : 10.1007/11917496_1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.66.9552
Clustering with partial information, MFCS, pp.144-155, 2008. ,
DOI : 10.1016/j.tcs.2009.12.016
URL : http://doi.org/10.1016/j.tcs.2009.12.016
The treewidth and pathwidth of hypercubes, Discrete Mathematics, vol.306, issue.3, pp.359-365, 2006. ,
DOI : 10.1016/j.disc.2005.12.011
An improved parameterized algorithm for the minimum node multiway cut problem, WADS, pp.495-506, 2007. ,
A fixed-parameter algorithm for the directed feedback vertex set problem, J. ACM, issue.5, p.55, 2008. ,
Seminar 07281 Open problems, Structure Theory and FPT Algorithmics for Graphs, Digraphs and Hypergraphs, 2007. ,
Correlation clustering in general weighted graphs, Theoretical Computer Science, vol.361, issue.2-3, pp.172-187, 2006. ,
DOI : 10.1016/j.tcs.2006.05.008
coloring: fast, easy, and hard cases, MFCS 2001, pp.304-315, 2001. ,
Finding small balanced separators, Proceedings of the thirty-eighth annual ACM symposium on Theory of computing , STOC '06, pp.375-384, 2006. ,
DOI : 10.1145/1132516.1132573
Parameterized Complexity Theory, 2006. ,
A logical approach to multicut problems, Information Processing Letters, vol.103, issue.4, pp.136-141, 2007. ,
DOI : 10.1016/j.ipl.2007.03.005
Logic, graphs, and algorithms, Logic and Automata-History and Perspectives, 2007. ,
FPT Algorithms for Path-Transversals and Cycle-Transversals Problems in Graphs, IWPEC, pp.129-140, 2008. ,
DOI : 10.1007/978-3-540-79723-4_13
URL : https://hal.archives-ouvertes.fr/hal-00824933
Complexity and exact algorithms for vertex multicut in interval and bounded treewidth graphs, European Journal of Operational Research, vol.186, issue.2, pp.542-553, 2008. ,
DOI : 10.1016/j.ejor.2007.02.014
Open problem session of Dagstuhl seminar 08431, 2008. ,
Simpler Parameterized Algorithm for OCT, IWOCA 2009, pp.380-384, 2009. ,
DOI : 10.1007/978-3-642-10217-2_37
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.157.4912
Parameterized graph separation problems, Theoretical Computer Science, vol.351, issue.3, pp.394-406, 2006. ,
DOI : 10.1016/j.tcs.2005.10.007
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.102.9011
Constant ratio fixed-parameter approximation of the edge multicut problem, ESA 2009, pp.647-658, 2009. ,
DOI : 10.1016/j.ipl.2009.07.016
Invitation to fixed-parameter algorithms, volume 31 of Oxford Lecture Series in Mathematics and its Applications, 2006. ,
On the structure of all minimum cuts in a network and applications, Combinatorial optimization, II (Proc. Conf., Univ. East Anglia, pp.8-16, 1979. ,
Almost 2-SAT is fixed-parameter tractable, ICALP (1), pp.551-562, 2008. ,
DOI : 10.1016/j.jcss.2009.04.002
URL : http://doi.org/10.1016/j.jcss.2009.04.002
Tree Width and Tangles: A New Connectivity Measure and Some Applications, Surveys in Combinatorics, pp.87-162, 1997. ,
DOI : 10.1017/CBO9780511662119.006
Finding odd cycle transversals, Operations Research Letters, vol.32, issue.4, pp.299-301, 2004. ,
DOI : 10.1016/j.orl.2003.10.009
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.112.6357
Graph minors. X. Obstructions to tree-decomposition, Journal of Combinatorial Theory, Series B, vol.52, issue.2, pp.153-190, 1991. ,
DOI : 10.1016/0095-8956(91)90061-N
URL : http://doi.org/10.1006/jctb.1999.1919
Complexity and applications of edge-induced vertex-cuts. CoRR, abs/cs/0607109, 2006. ,
Algorithms for Multiterminal Cuts, CSR, pp.314-325, 2008. ,
DOI : 10.1007/978-3-540-79709-8_32
