The probabilistic method. Wiley-Interscience Series in Discrete Mathematics and Optimization, 2000. ,
Short proofs are narrow---resolution made simple, Journal of the ACM, vol.48, issue.2, pp.149-169, 2001. ,
DOI : 10.1145/375827.375835
A machine program for theorem-proving, Communications of the ACM, vol.5, issue.7, pp.394-397, 1962. ,
DOI : 10.1145/368273.368557
An efficient algorithm for the minimal unsatisfiability problem for a subclass of CNF, Ann. Math. Artificial Intelligence, vol.23, pp.3-4229, 1998. ,
Problems and results on 3-chromatic hypergraphs and some related questions, Infinite and Finite Sets, pp.609-627, 1975. ,
Lopsided Lov??sz Local Lemma and Latin transversals, Discrete Applied Mathematics, vol.30, issue.2-3, pp.151-154, 1988. ,
DOI : 10.1016/0166-218X(91)90040-4
Disproof of the Neighborhood Conjecture with Implications to SAT, 17th Annual European Symposium on Algorithms, pp.764-775, 2009. ,
DOI : 10.1007/978-3-642-04128-0_68
Computing unsatisfiable <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>k</mml:mi></mml:math>-SAT instances with few occurrences per variable, Theoretical Computer Science, vol.337, issue.1-3, pp.347-359, 2005. ,
DOI : 10.1016/j.tcs.2005.02.004
-CNF Formulas with Few Occurrences per Variable, SIAM Journal on Discrete Mathematics, vol.20, issue.2, pp.523-528, 2006. ,
DOI : 10.1137/S0895480104445745
URL : https://hal.archives-ouvertes.fr/jpa-00214615
Coloring uniform hypergraphs with few edges, Random Structures and Algorithms, vol.1, issue.3 ,
DOI : 10.1002/rsa.20284
Constructions of sparse uniform hypergraphs with high chromatic number, Random Structures and Algorithms, vol.1, issue.1 ,
DOI : 10.1002/rsa.20293
One More Occurrence of Variables Makes Satisfiability Jump from Trivial to NP-Complete, SIAM Journal on Computing, vol.22, issue.1, pp.203-210, 1993. ,
DOI : 10.1137/0222015
On the difference between asymptotically good packings and coverings, European Journal of Combinatorics, vol.16, issue.1, pp.35-40, 1995. ,
DOI : 10.1016/0195-6698(95)90087-X
Using Lovász Local Lemma in the space of random injections, Electron. J. Combin, vol.14, issue.13, p.pp, 2007. ,
On Linear CNF Formulas, SAT, pp.212-225, 2006. ,
DOI : 10.1007/11814948_22
Linear CNF formulas and satisfiability, Discrete Applied Mathematics, vol.157, issue.5, pp.1046-1068, 2009. ,
DOI : 10.1016/j.dam.2008.03.031
DNF tautologies with a limited number of occurrences of every variable, Theoretical Computer Science, vol.238, issue.1-2, pp.495-498, 2000. ,
DOI : 10.1016/S0304-3975(00)00036-0
Unsatisfiable linear k-CNFs exist, for every k. CoRR, abs/0708, 2007. ,
Homomorphisms of conjunctive normal forms, Discrete Applied Mathematics, vol.130, issue.2, pp.351-365, 2003. ,
DOI : 10.1016/S0166-218X(02)00411-0
A simplified NP-complete satisfiability problem, Discrete Applied Mathematics, vol.8, issue.1, pp.85-89, 1984. ,
DOI : 10.1016/0166-218X(84)90081-7
Abstract, Bulletin of Symbolic Logic, vol.35, issue.04, pp.425-467, 1995. ,
DOI : 10.1145/136035.136043
