Approximate Models for Wave Propagation Across Thin Periodic Interfaces - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2010
(1, 2) , (3) , (2)
1
2
3
This work deals with the scattering of acoustic waves by a thin ring which contains many regularly-spaced heterogeneties. We provide a complete description of the asymptotic of the solution with respect to the period and the thickness of the heterogeneities. Then, we build a simplified model replacing the thin perforated ring by an effective transmission condition. We pay particular attention to the stabilization of the effective transmission condition. Error estimates and numerical simulations are carried out to validate the accuracy of the model.
RR-7197.pdf (1.16 Mo) Télécharger le fichier
Dates and versions
inria-00456200 , version 1 (12-02-2010)
Identifiers
  • HAL Id : inria-00456200 , version 1
Cite
Bérangère Delourme, Houssem Haddar, Patrick Joly. Approximate Models for Wave Propagation Across Thin Periodic Interfaces. [Research Report] RR-7197, INRIA. 2010. ⟨inria-00456200⟩
306 View
213 Download
Share
