An O(log 2 k)-competitive algorithm for metric bipartite matching, Proceedings of the 15th Annual European Symposium on Algorithms, pp.522-533, 2007. ,
Efficient algorithms for constructing (1+???,??)-spanners in the distributed and streaming models, Distributed Computing, vol.51, issue.3, pp.375-385, 2006. ,
DOI : 10.1007/s00446-005-0147-2
Improved Approximation Guarantees for Weighted Matching in the Semi-streaming Model, SIAM Journal on Discrete Mathematics, vol.25, issue.3, 2009. ,
DOI : 10.1137/100801901
URL : https://hal.archives-ouvertes.fr/inria-00456411
On graph problems in a semi-streaming model, Theoretical Computer Science, vol.348, issue.2-3, pp.207-216, 2005. ,
DOI : 10.1016/j.tcs.2005.09.013
Graph Distances in the Data-Stream Model, SIAM Journal on Computing, vol.38, issue.5, pp.1709-1727, 2008. ,
DOI : 10.1137/070683155
Efficient On-Line Call Control Algorithms, Journal of Algorithms, vol.23, issue.1, pp.180-194, 1997. ,
DOI : 10.1006/jagm.1996.0821
Online Weighted Matching, Journal of Algorithms, vol.14, issue.3, pp.478-488, 1993. ,
DOI : 10.1006/jagm.1993.1026
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.54.2873
Searching in an Unknown Environment: An Optimal Randomized Algorithm for the Cow-Path Problem, Information and Computation, vol.131, issue.1, pp.63-79, 1996. ,
DOI : 10.1006/inco.1996.0092
An optimal algorithm for on-line bipartite matching, Proceedings of the twenty-second annual ACM symposium on Theory of computing , STOC '90, pp.352-358, 1990. ,
DOI : 10.1145/100216.100262
On-line algorithms for weighted bipartite matching and stable marriages, Theoretical Computer Science, vol.127, issue.2, pp.255-267, 1994. ,
DOI : 10.1016/0304-3975(94)90042-6
Engineering Algorithms for Approximate Weighted Matching, Proceedings of the 6th International Workshop on Experimental Algorithms, pp.242-255, 2007. ,
DOI : 10.1007/978-3-540-72845-0_19
Finding Graph Matchings in Data Streams, Proceedings of the 8th International Workshop on Approximation Algorithms for Combinatorial Optimization Problems, pp.170-181, 2005. ,
DOI : 10.1007/11538462_15
Implementing weighted b-matching algorithms, Journal of Experimental Algorithmics, vol.4, p.7, 1999. ,
DOI : 10.1145/347792.347815
Data Streams: Algorithms and Applications. Foundations and Trends in Theoretical Computer Science, 2005. ,
DOI : 10.1561/0400000002
URL : http://ce.sharif.edu/courses/90-91/1/ce797-1/resources/root/Data_Streams_-_Algorithms_and_Applications.pdf
Combinatorial Optimization: Polyhedra and Efficiency, 2003. ,
Weighted Matching in the Semi-Streaming Model, Proceedings of the 25th Annual Symposium on Theoretical Aspects of Computer Science, pp.669-680, 2008. ,
DOI : 10.1007/s00453-010-9438-5
URL : https://hal.archives-ouvertes.fr/hal-00255934
