New interface
Conference papers
Model-driven Simulation of a Maritime Surveillance System
Abstract : This paper reports an industrial experiment made at Thales to use Model Driven Architecture (MDA) for system engineering. System engineering processes are currently mainly document-centric. The main experiment goal was to study the applicability of MDA at the system engineering level. The experiment consisted of setting up a model-driven simulation environment for a maritime surveillance system. The simu- lation is achieved thanks to 3 models conform to 3 metamodels. The implementation uses the Eclipse Modeling Framework and is written in the Java Programming language. This pilot project met the deadline, the budget and the threshold of desired functionalities. We report the main advances given by the MDA approach in the context of simulation for system engineering.
Document type :
Conference papers
Complete list of metadata
Cited literature [3 references]  Display  Hide  Download
https://hal.inria.fr/inria-00456481
Contributor : Didier Vojtisek Connect in order to contact the contributor
Submitted on : Monday, February 15, 2010 - 11:36:24 AM
Last modification on : Friday, February 4, 2022 - 3:18:50 AM
Long-term archiving on: : Thursday, October 18, 2012 - 3:07:04 PM
File
Monperrus08a.pdf
Identifiers
Citation
Martin Monperrus, Fabre Jaozafy, Gabriel Marchalot, Joël Champeau, Brigitte Hoeltzener, et al.. Model-driven Simulation of a Maritime Surveillance System. 4th European Conference on Model Driven Architecture Foundations and Applications (ECMDA'2008), Jun 2008, Berlin, Germany, Germany. pp.361-368, ⟨10.1007/978-3-540-69100-6_25⟩. ⟨inria-00456481⟩
Share
Metrics
Record views
262
Files downloads
226
