New interface
Conference papers
Test-Driven Assessment of Access Control in Legacy Applications
Abstract : If access control policy decision points are not neatly separated from the business logic of a system, the evolution of a security policy likely leads to the necessity of changing the system's code base. This is often the case with legacy systems. We present a test-driven methodology to assess the flexibility of a system, a property that describes the degree of coupling between the access control logic and the business logic of a system. A low flexibility indicates that a modification of the policy will lead to substantial changes of the code. In this paper, we analyze the notion of flexibility which is related to the presence of hidden and implicit security mechanisms in the business logic. We detail how testing can be used for detecting such mechanisms and how it may drive the incremental evolution of a security policy. We use several case studies to illustrate and validate the methodology.
Document type :
Conference papers
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/inria-00456953
Contributor : Didier Vojtisek Connect in order to contact the contributor
Submitted on : Tuesday, February 16, 2010 - 10:42:47 AM
Last modification on : Friday, February 4, 2022 - 3:16:16 AM
Long-term archiving on: : Friday, June 18, 2010 - 9:01:30 PM
File
mouelhi08c.pdf
Identifiers
  • HAL Id : inria-00456953, version 1
Citation
Yves Le Traon, Tejeddine Mouelhi, Alexander Pretschner, Benoit Baudry. Test-Driven Assessment of Access Control in Legacy Applications. ICST 2008 : First IEEE International Conference on Software, Testing, Verification and Validation (ICST), April 9-11, Lillehammer, Norway, RSM - Dépt. Réseaux, Sécurité et Multimédia (Institut TELECOM ; TELECOM Bretagne), ETH - Eidgenössische Technische Hochschule Zürich (ETH Zurich), IRISA - Institut de Recherche en Informatique et Systèmes aléatoires (INRIA), 2008, Lillehammer, Norway. ⟨inria-00456953⟩
Share
Metrics
Record views
171
Files downloads
328
