Optimal stopping problems for some Markov processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Annals of Applied Probability Année : 2012
In this paper, we solve explicitly the optimal stopping problem with random discounting and an additive functional as cost of observations for a regular linear diffusion. We also extend the results to the class of one-sided regular Feller processes. This generalizes the result of Beibel and Lerche [Statist. Sinica 7 (1997) 93-108] and [Teor. Veroyatn. Primen. 45 (2000) 657-669] and Irles and Paulsen [Sequential Anal. 23 (2004) 297-316]. Our approach relies on a combination of techniques borrowed from potential theory and stochastic calculus. We illustrate our results by detailing some new examples ranging from linear diffusions to Markov processes of the spectrally negative type.
aap795.pdf (266.75 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00458901 , version 1 (22-02-2010)
inria-00458901 , version 2 (25-02-2010)
inria-00458901 , version 3 (15-06-2011)
inria-00458901 , version 4 (05-11-2012)
Mamadou Cissé, Pierre Patie, Etienne Tanré. Optimal stopping problems for some Markov processes. The Annals of Applied Probability, 2012, 22 (3), pp.1243-1265. ⟨10.1214/11-AAP795⟩. ⟨inria-00458901v4⟩
254 Consultations
556 Téléchargements
