Conference papers
Sensors deployment enhancement by a mobile robot in wireless sensor networks
Ridha Soua 1 Leila Azouz Saidane 1 Pascale Minet 2
2 HIPERCOM - High performance communication
Inria Paris-Rocquencourt, UP11 - Université Paris-Sud - Paris 11, Inria Saclay - Ile de France, X - École polytechnique, CNRS - Centre National de la Recherche Scientifique : UMR
Abstract : An inherent concern for a wireless sensor network (WSN) is the coverage problem. Sensors are usually deployed in the wild to create a network of sensors intended to monitor or control a target area: Sensor networks are assumed unattended in various environments such as disaster areas, hazard fields, or battle fields. However, random node deployment often makes initial sensing holes inside the deployed area inevitable even in an extremely high density network. Furthermore, enhancing coverage is important for sensor networks to provide continuous sensing services. The most challenging aspects of the studies conducted on this topic have been supporting autonomous system with self maintenance capability where sensors and robots work together. This paper proposes to use a mobile robot to assist the initial sensors deployment and to improve sensing coverage and connectivity of monitored area. Given a set of points of interest on the surface, we study how to guide the robot to effectively eliminate coverage holes and collect redundant sensors. We propose a set of heuristics for this problem and we will verify the performance through simulation. The superior coverage and connectivity efficiency of the proposed approach is demonstrated by conducting a comparative analysis and simulation with a greedy approach.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00459375
Contributor : Pascale Minet Connect in order to contact the contributor
Submitted on : Tuesday, February 23, 2010 - 5:29:43 PM
Last modification on : Sunday, June 26, 2022 - 11:51:29 AM
Identifiers
  • HAL Id : inria-00459375, version 1
Collections
X | CNRS | INRIA | INRIA2
Citation
Ridha Soua, Leila Azouz Saidane, Pascale Minet. Sensors deployment enhancement by a mobile robot in wireless sensor networks. Ninth International Conference on Networks - ICN 2010, Apr 2010, Les Menuires, France. ⟨inria-00459375⟩
Share
Metrics
Record views
209
