S. Bae, S. Paris, and F. And-durand, Two-scale tone management for photographic look, ACM Transactions on Graphics, vol.25, issue.3, pp.637-645, 2006.
DOI : 10.1145/1141911.1141935
B. , P. J. And-adelson, and E. H. , The laplacian pyramid as a compact image code, IEEE Trans. on Communications COM- 31, vol.4, pp.532-540, 1983.
C. , J. Paris, S. And-durand, and F. , Real-time edgeaware image processing with the bilateral grid, ACM Transactions on Graphics, vol.103, 2007.
C. , P. And-tumblin, and J. , The trilateral filter for high contrast images and meshes, SIGGRAPH '05: ACM SIGGRAPH 2005 Courses, 2005.
D. , C. Meignen, S. And-perrier, and V. , A fast algorithm for bidimensional emd, Signal Processing Letters IEEE, vol.12, issue.10, pp.701-704, 2005.
D. , F. And-dorsey, and J. , Fast bilateral filtering for the display of high-dynamic-range images, ACM Transactions on Graphics: SIGGRAPH '02, pp.257-266, 2002.
F. , Z. Fattal, R. Lischinski, D. And-szeliski, and R. , Edge-preserving decompositions for multi-scale tone and detail manipulation, ACM Transactions on Graphics, vol.67, 2008.
F. , R. Agrawala, M. And-rusinkiewicz, and S. , Multiscale shape and detail enhancement from multi-light image collections, ACM Transactions on Graphics, p.51, 2007.
L. , R. L. Biemond, J. And-boekee, and D. E. , Regularized iterative image restoration with ringing reduction, 1988.
L. , A. Lischinski, D. And-weiss, and Y. , Colorization using optimization, ACM Transactions on Graphics, vol.23, pp.689-694, 2004.
L. , H. , Y. , L. And-huang, and D. , The study of the intermittency test filtering character of hilbert-huang transform, Mathematics and Computers in Simulation, vol.70, issue.1, pp.22-32, 2005.
L. , D. Farbman, Z. Uyttendaele, M. And-szeliski, and R. , Interactive local adjustment of tonal values, ACM Transactions on Graphics, vol.25, issue.3, pp.646-653, 2006.
L. , Z. And-peng, and S. , Boundary processing of bidimensional emd using texture synthesis, Signal Processing Letters IEEE, vol.12, issue.1, pp.33-36, 2005.
N. , J. Niang, O. Bouaoune, Y. Delechelle, E. And-bunel et al., Texture analysis based on the bidimensional empirical mode decomposition with gray-level co-occurrence models, Signal Processing and Its Applications, pp.633-635, 2003.
O. , B. M. Chen, M. Dorsey, J. And-durand, and F. , Image-based modeling and photo editing, Proceedings of SIG- GRAPH 2001, pp.433-442, 2001.
P. , S. N. Fairchild, M. Ferwerda, J. And-greenberg, and D. P. , Multiscale model of adaptation, spatial vision and color appearance, 1998.
R. , Z. U. And-woodell, and G. A. , A multi-scale retinex for bridging the gap between color images and the human observation of scenes, In IEEE Trans. on Image Processing: Special Issue on Color Processing, vol.67, pp.965-976, 1997.
S. , J. , A. Vincent, and L. , An overview of morphological filtering, Circuits, Systems and Signal Processing, pp.47-108, 1992.
T. , C. And-manduchi, and R. , Bilateral filtering for gray and color images, Proc. of the Sixth International Conference on Computer Vision, 1998.
T. , J. And-turk, and G. , Lcis: a boundary hierarchy for detail-preserving contrast reduction, Proceedings of SIG- GRAPH '99, pp.83-90, 1999.
W. Farbman, Our smoothing extracts features based on spatial scale while other methods smooth low-contrast features first. Using our decomposition, the pebbles and stones towards the bottom of the image are extracted as fineand medium-scale detail respectively, even though they are well contrasted. On the other hand, despite their low contrast, the clouds are not extracted as detail due to their coarse scale. The comparison images have been directly taken from, Figure, vol.15, 1999.
