Initial CONNECT Architecture
Abstract : Interoperability remains a fundamental challenge when connecting heterogeneous systems which encounter and spontaneously communicate with one another in pervasive computing environments. This challenge is exasperated by the highly heterogeneous technologies employed by each of the interacting parties, i.e., in terms of hardware, operating system, middleware protocols, and application protocols. The key aim of the CONNECT project is to drop this heterogeneity barrier and achieve universal interoperability. Here we report on the development of the overall CONNECT architecture that will underpin this solution; in this respect, we present the following contributions: i) an elicitation of interoperability requirements from a set of pervasive computing scenarios, ii) a survey of existing solutions to interoperability, iii) an initial view of the CONNECT architecture, and iv) a series of experiments to provide initial validation of the architecture.
Type de document :
Rapport
[Technical Report] 2010
Liste complète des métadonnées
Littérature citée [80 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00464644
Contributeur : Emmanuelle Grousset <>
Soumis le : mercredi 17 mars 2010 - 16:21:42
Dernière modification le : vendredi 25 mai 2018 - 12:02:02
Document(s) archivé(s) le : vendredi 18 juin 2010 - 23:34:20
Fichier
connect_WP1_D11_300dpi_.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00464644, version 1
Collections
Citation
Antonia Bertolino, Gordon Blair, Franck Chauvel, Carlos Flores Cortes, Nikolaos Georgantas, et al.. Initial CONNECT Architecture. [Technical Report] 2010. 〈inria-00464644〉
Métriques
Consultations de la notice
406
Téléchargements de fichiers
209
