Systems Engineering with SysML/UML: Modeling, Analysis, Design . The MK, 2008. ,
The Essence of Multilevel Metamodeling. UML -The Unied Modeling Language, Modeling Languages, Concepts, and Tools, p.2185, 1933. ,
Reducing accidental complexity in domain models, Software & Systems Modeling, vol.3, issue.3, p.345359, 2008. ,
DOI : 10.1007/s10270-007-0061-0
Classes versus prototypes in object-oriented languages, Proc. of the Fall Joint Computer Conference, p.3640, 1986. ,
Using prototypical objects to implement shared behavior in objectoriented systems In: OOPLSA'86: Conference proceedings on Object-oriented programming systems, languages and applications, p.214223, 1986. ,
An exemplar based smalltalk, p.322330, 1986. ,
Can programming be liberated from the two-level style? Multi-level programming with DeepJava, OOPSLA'07: Proc. of the 22 nd annual ACM SIGPLAN conf. on Object oriented programming systems and applications, p.229244, 2007. ,
Nivel: a metamodelling language with a formal semantics, Software and System Modeling, p.521549, 2009. ,
DOI : 10.1007/s10270-008-0103-2
Connecting Powertypes and Stereotypes., The Journal of Object Technology, vol.4, issue.7, p.8396, 2005. ,
DOI : 10.5381/jot.2005.4.7.a3
Modeling Time(s), Proc., 10th Int. Conf. on Model Driven Engineering Languages and Systems (MoDELS'07, p.559573, 2007. ,
DOI : 10.1007/978-3-540-75209-7_38
Towards a Framework for Explicit Platform-Based Transformations, 2008 11th IEEE International Symposium on Object and Component-Oriented Real-Time Distributed Computing (ISORC), 2008. ,
DOI : 10.1109/ISORC.2008.64
In: Type Object, p.4765, 1997. ,
Object-oriented patterns, Communications of the ACM, vol.35, issue.9, p.152159, 1992. ,
DOI : 10.1145/130994.131006
In: Power Types. Volume 12 of SIGS Reference Library, 1998. ,
No Silver Bullet Essence and Accidents of Software Engineering, Computer, vol.20, issue.4, p.1019, 1987. ,
DOI : 10.1109/MC.1987.1663532
Multilevel modeling paradigm in prole denition, 2008. ,
An Introduction to UML Proles, UML and Model Engineering V, issue.2, 2004. ,
A systematic approach to domain-specic language design using uml, 10 th IEEE Int. Symp. on Object-Oriented Real-Time Distributed Computing (ISORC'07), p.29, 2007. ,
