The Clock Constraint Specification Language for building timed causality models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Innovations in Systems and Software Engineering Année : 2010
The UML Profile for Modeling and Analysis of Real-Time and Embedded (RTE) systems has recently been adopted by the OMG. Its Time Model extends the informal and simplistic Simple Time package proposed by Unified Modeling Language (UML2) and offers a broad range of capabilities required to model RTE systems including discrete/dense and chronometric/logical time. The Marte specification introduces a Time Structure inspired from several time models of the concurrency theory and proposes a new clock constraint specification language (CCSL) to specify, within the context of the UML, logical and chronometric time constraints. A semantic model in CCSL is attached to a (UML) model to give its timed causality semantics. In that sense, CCSL is comparable to the Ptolemy environment, in which directors give the semantics to models according to predefined models of computations and communication. This paper focuses on one historical model of computation of Ptolemy [SynchronousData Flow(SDF)] and shows how to build SDF graphs by combining UML and CCSL models.
Mots clés
inria-00464894 , version 1 (18-03-2010)
Frédéric Mallet, Julien Deantoni, Charles André, Robert de Simone. The Clock Constraint Specification Language for building timed causality models. Innovations in Systems and Software Engineering, 2010, 6 (1-2), pp.99-106. ⟨10.1007/s11334-009-0109-0⟩. ⟨inria-00464894⟩
321 Consultations
0 Téléchargements
