Selective Hybrid-ARQ turbo schemes with various Combining methods in Fading Channels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2003
Diversity combining offers a large variety of schemes for improved bit-error-rate (BER) in packet communications. The majority of the schemes are designed to combat noise. The scheme considers metric ratio combining (MRC), Chase combining and code combining. The paper also simulates and derives the theoretical average throughput of a diversity combining schemes employing turbo coding over Rayleigh fading channels. The paper proposes an expression for the selection of hybrid ARQ schemes based on a signal-to-interference-plus-noise-ratio (SINR), in the presence of cochannel interference. The presented SINR expression reduces to an average signal-to-noise ratio (SNR) when no co-channel interference exists.
OtengAmoako-selective.pdf (118.91 Ko) Télécharger le fichier
inria-00466064 , version 1 (22-03-2010)
  • HAL Id : inria-00466064 , version 1
Kingsley Oteng-Amoako, Jinhong Yuan, Saeid Nooshabadi. Selective Hybrid-ARQ turbo schemes with various Combining methods in Fading Channels. WiOpt'03: Modeling and Optimization in Mobile, Ad Hoc and Wireless Networks, Mar 2003, Sophia Antipolis, France. 3 p. ⟨inria-00466064⟩
Collections
WIOPT2003
62 Consultations
99 Téléchargements
