R. H. Deng, Hybrid ARQ scheme using TCM and code combining, Electronics Letters, vol.27, issue.10, pp.866-868, 1991.
DOI : 10.1049/el:19910542
D. Chase, Code Combining--A Maximum-Likelihood Decoding Approach for Combining an Arbitrary Number of Noisy Packets, IEEE Transactions on Communications, vol.33, issue.5, pp.385-393, 1985.
DOI : 10.1109/TCOM.1985.1096314
H. Jack and . Winters, Optimum Combining in Digital Mobile Radio with Co-channel interference, IEEE Journal on Selected Area in Commun, vol.2, issue.4, 1984.
S. Lin, D. J. Costello, and J. , Error Control Coding Fundamentals and Applications, 1983.
C. Berroux and A. Glavieux, Near optimum error correcting coding and decoding: turbo-codes, IEEE Transactions on Communications, vol.44, issue.10, pp.77-79, 1997.
DOI : 10.1109/26.539767
S. Lin and P. S. Yu, A Hybrid ARQ Scheme with Parity Retransmission for Error Control of Satellite Channels, IEEE Transactions on Communications, vol.30, issue.7, pp.1701-1719, 1982.
DOI : 10.1109/TCOM.1982.1095643
G. Benedetto and . Montorsi, Design of parallel concatenated convolutional codes, IEEE Transactions on Communications, vol.44, issue.5, pp.591-600, 1996.
DOI : 10.1109/26.494303
F. Divsalar and . Pollara, On the design of Turbo codes, pp.99-121, 1995.
D. Divsalar and R. J. Mceliece, Effective free distance of turbo codes, Electronics Letters, vol.32, issue.5, pp.445-446, 1996.
DOI : 10.1049/el:19960321
G. M. Benedetto and R. Garello, A search for good convolutional codes to be used in the construction of turbo codes, IEEE Transactions on Communications, vol.46, issue.9, pp.1101-1112, 1998.
DOI : 10.1109/26.718548
L. R. Bahl, J. Cocke, F. Jelinek, and J. Raviv, Optimal decoding of linear codes for minimizing symbol error rate (Corresp.), IEEE Transactions on Information Theory, vol.20, issue.2, pp.284-287, 1974.
DOI : 10.1109/TIT.1974.1055186
D. Divsalar, S. Dolinar, and F. Pollara, Proposal for CCSDS Turbo Codes: Deep Space and New Earth, NASA JPL, 1996.
D. N. Rowitch and L. B. Milstein, On the Performance of Hybrid FEC, ARW Systems Using Rate Compatible Punctured Turbo (RCPT) Codes " NASA JPL, 1996.
D. N. Rowitch and L. B. Milstein, Rate compatible puncture turbo (RCPT) codes in hybrid FEC/ARQ, Proc. Comm. Theory, Miniconference of Globecomm '97 pp, pp.55-59, 1997.
