Conserving Energy in Dense Sensor Networks via Distributed Scheduling
In this paper, we perform an initial investigation into the problem of scheduling the on periods of sensor nodes in densely covered regions. Our goal is to reduce energy consumption per sensor while maintaining sufficient coverage of all regions that the sensors were deployed to cover.
