Adaptive Management of Bluetooth Slave/Slave Bridge
Abstract : This paper discusses the minimization of end-to-end delays in a small Bluetooth scatternet with a Slave/Slave bridge. We assume that both piconets operate under exhaustive scheduling policy, that slaves generate packet bursts, that burst arrivals follow Poisson distribution, and that the size of packet bursts follows geometric distribution. Using the theory of queues with vacations, we investigate the possibility of choosing scatternet parameters so as to minimize the aforementioned delays. We show that the minimization of delay should use the time interval between bridge exchanges in order to minimize inter-piconet traffic, since the intra-piconet traffic delay is less sensitive to the actual value of the time interval between bridge exchanges. Then, we present a load adaptive algorithm that would change this time dynamically, and show how the end-to-end delay is indeed minimized in this manner. Simulation results confirm that the algorithm is able to achieve minimum endto- end delay for inter-piconet traffic under a wide range of traffic loads.
Type de document :
Communication dans un congrès
WiOpt'03: Modeling and Optimization in Mobile, Ad Hoc and Wireless Networks, Mar 2003, Sophia Antipolis, France. 10 p., 2003
Liste complète des métadonnées
Littérature citée [23 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00466710
Contributeur : Service Ist Inria Sophia Antipolis-Méditerranée / I3s <>
Soumis le : mercredi 24 mars 2010 - 15:44:50
Dernière modification le : mercredi 24 mars 2010 - 20:56:04
Document(s) archivé(s) le : vendredi 25 juin 2010 - 12:20:29
Fichier
misic-adaptvie.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00466710, version 1
Collections
Citation
Jelena Misic, Vojislav B. Misic. Adaptive Management of Bluetooth Slave/Slave Bridge. WiOpt'03: Modeling and Optimization in Mobile, Ad Hoc and Wireless Networks, Mar 2003, Sophia Antipolis, France. 10 p., 2003. 〈inria-00466710〉
Métriques
Consultations de la notice
201
Téléchargements de fichiers
102
