Representation-Independent In-Place Magnification with Sigma Lenses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2010
Emmanuel Pietriga
Olivier Bau
  • Fonction : Auteur
  • PersonId : 868347
Caroline Appert
Focus+context interaction techniques based on the metaphor of lenses are used to navigate and interact with objects in large information spaces. They provide in-place magnification of a region of the display without requiring users to zoom into the representation and consequently lose context. In order to avoid occlusion of its immediate surroundings, the magnified region is often integrated in the context using smooth transitions based on spatial distortion. Such lenses have been developed for various types of representations using techniques often tightly coupled with the underlying graphics framework. We describe a representation-independent solution that can be implemented with minimal effort in different graphics frameworks, ranging from 3D graphics to rich multi-scale 2D graphics combining text, bitmaps and vector graphics. Our solution is not limited to spatial distortion and provides a unified model that makes it possible to define new focus+context interaction techniques based on lenses whose transition is defined by a combination of dynamic displacement and compositing functions. We present the results of a series of user evaluations that show that one such new lens, the speed-coupled blending lens, significantly outperforms all others.
tvcg2009_sigma_lenses.pdf (1.9 Mo) Télécharger le fichier
TVCG-2009-03-0060_video.mov (35.61 Mo) Télécharger le fichier
Format : Figure, Image
inria-00467658 , version 1 (27-03-2010)
Emmanuel Pietriga, Olivier Bau, Caroline Appert. Representation-Independent In-Place Magnification with Sigma Lenses. IEEE Transactions on Visualization and Computer Graphics, 2010, 16 (3), pp.455-467. ⟨10.1109/TVCG.2009.98⟩. ⟨inria-00467658⟩
405 Consultations
490 Téléchargements
