Object-Oriented Design of Real-Time Telecom Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
Many engineers are still reluctant to adopt advanced object-oriented technologies (such as high modularity, dynamic binding, automatic garbage collection, etc.) for embedded systems with real-time constraints, because of their supposed inefficiency. We set ourselves into the context of building telecommunication systems with a standard object-oriented analysis and design approach. We describe how we use relevant design patterns, followed with an implementation in a pure object-oriented language (Eiffel) to conciliate the needed efficiency with the benefits of the object-oriented approach —flexibility, dynamic configurability, maintenability, portability, etc. We discuss a case study based on the implementation of SMDS (Switched Multi-megabits Data Service) servers featuring high-throughput and low-delay transmissions and respecting the real-time constraints of SMDS.
isorc.pdf (79.76 Ko) Télécharger le fichier
inria-00468946 , version 1 (01-04-2010)
  • HAL Id : inria-00468946 , version 1
Jean-Marc Jézéquel. Object-Oriented Design of Real-Time Telecom Systems. ISORC'98, Apr 1998, Kyoto, Japan. ⟨inria-00468946⟩
210 Consultations
916 Téléchargements
