Matrix-based Implicit Representations of Rational Algebraic Curves and Applications
Given a parameterization of an algebraic rational curve in a projective space of arbitrary dimension, we introduce and study a new implicit representation of this curve which consists in the locus where the rank of a single matrix drops. Then, we illustrate the advantages of this representation by addressing several important problems of Computer Aided Geometric Design: The point-on-curve and inversion problems, the computation of singularities and the intersection problem between two rational curves.
Calcul formel [cs.SC]
