Matrix-based Implicit Representations of Rational Algebraic Curves and Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Aided Geometric Design Année : 2010
Given a parameterization of an algebraic rational curve in a projective space of arbitrary dimension, we introduce and study a new implicit representation of this curve which consists in the locus where the rank of a single matrix drops. Then, we illustrate the advantages of this representation by addressing several important problems of Computer Aided Geometric Design: The point-on-curve and inversion problems, the computation of singularities and the intersection problem between two rational curves.
MatrixRepCurve.pdf (248.71 Ko) Télécharger le fichier
inria-00468964 , version 1 (01-04-2010)
inria-00468964 , version 2 (09-09-2010)
Laurent Busé, Thang Luu Ba. Matrix-based Implicit Representations of Rational Algebraic Curves and Applications. Computer Aided Geometric Design, 2010, 27 (9), pp.681-699. ⟨10.1016/j.cagd.2010.09.006⟩. ⟨inria-00468964v2⟩
308 Consultations
513 Téléchargements
