Replacing suffix trees with enhanced suffix arrays, Journal of Discrete Algorithms, vol.2, issue.1, pp.53-86, 2004. ,
DOI : 10.1016/S1570-8667(03)00065-0
Compression of biological sequences by greedy offline textual substitution, Proc. Data Compression Conference, pp.143-152, 2000. ,
Off-line compression by greedy textual substitution, Proc. IEEE volume, pp.1733-1744, 2000. ,
DOI : 10.1109/5.892709
A corpus for the evaluation of lossless compression algorithms, Proceedings DCC '97. Data Compression Conference, 1997. ,
DOI : 10.1109/DCC.1997.582019
Compressed indexes for dynamic text collections, ACM Transactions on Algorithms, vol.3, issue.2, 2007. ,
DOI : 10.1145/1240233.1240244
On updating suffix tree labels, Theoretical Computer Science, vol.201, issue.1-2, pp.249-262, 1998. ,
DOI : 10.1016/S0304-3975(97)00243-0
Data compression with finite windows, Communications of the ACM, vol.32, issue.4, pp.490-505, 1989. ,
DOI : 10.1145/63334.63341
An efficient algorithm for dynamic text indexing, Proc. ACM-SIAM symposium on Discrete Algorithms, pp.697-704, 1994. ,
Simple Linear Work Suffix Array Construction, Proc. International Conference on Automata, Languages and Programming, 2003. ,
DOI : 10.1007/3-540-45061-0_73
Grammar-based codes: a new class of universal lossless source codes, IEEE Transactions on Information Theory, vol.46, issue.3, 2000. ,
DOI : 10.1109/18.841160
Space efficient linear time construction of suffix arrays, Proc. Combinatorial Pattern Matching volume 2676, pp.200-210, 2003. ,
Finding maximal repetitions in a word in linear time, 40th Annual Symposium on Foundations of Computer Science (Cat. No.99CB37039), pp.596-604, 1999. ,
DOI : 10.1109/SFFCS.1999.814634
URL : https://hal.archives-ouvertes.fr/inria-00098853
Linear time construction of suffix arrays, Proc. Combinatorial Pattern Matching volume 2676, pp.186-2003, 2003. ,
Estimating dna sequence entropy, Proc. ACM-SIAM symposium on Discrete Algorithms, pp.409-418, 2000. ,
Faster suffix sorting, Theoretical Computer Science, vol.387, issue.3, 1999. ,
DOI : 10.1016/j.tcs.2007.07.017
URL : http://doi.org/10.1016/j.tcs.2007.07.017
An efficient, versatile approach to suffix sorting, Journal of Experimental Algorithmics, vol.12, pp.1-23, 2008. ,
DOI : 10.1145/1227161.1278374
Engineering a Lightweight Suffix Array Construction Algorithm, Algorithmica, vol.40, issue.1, pp.33-50, 2004. ,
DOI : 10.1007/s00453-004-1094-1
A Space-Economical Suffix Tree Construction Algorithm, Journal of the ACM, vol.23, issue.2, pp.262-272, 1976. ,
DOI : 10.1145/321941.321946
An implementation of the induced sorting algorithm, 2008. ,
Simple Linear-Time Off-Line Text Compression by Longest-First Substitution, 2007 Data Compression Conference (DCC'07), 2007. ,
DOI : 10.1109/DCC.2007.70
Identifying hierarchical structure in sequences: A linear-time algorithm, Journal of Artificial Intelligence Research, vol.7, pp.67-82, 1997. ,
On-line and off-line heuristics for inferring hierarchies of repetitions in sequences, Proc. Data Compression Conference, 2000. ,
DOI : 10.1109/5.892710
A taxonomy of suffix array construction algorithms, ACM Computing Surveys, vol.39, issue.2, 2007. ,
DOI : 10.1145/1242471.1242472
Efficient approximate and dynamic matching of patterns using a labeling paradigm, Proceedings of 37th Conference on Foundations of Computer Science, 1996. ,
DOI : 10.1109/SFCS.1996.548491
Dynamic burrows-wheeler transform, Proc. Prague Stringology Club, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00469530
An incomplex algorithm for fast suffix array construction, Software: Practice and Experience, vol.12, issue.3, pp.309-329, 2007. ,
DOI : 10.1002/spe.768
Time and Space Efficient Search for Small Alphabets with Suffix Arrays, Proc. Conference on Fuzzy Systems and Knowledge Discovery, 2005. ,
DOI : 10.1007/11539506_136
On-line construction of suffix trees, Algorithmica, vol.10, issue.3, pp.249-260, 1995. ,
DOI : 10.1007/BF01206331
Fast and Space Efficient Linear Suffix Array Construction, Data Compression Conference (dcc 2008), 2008. ,
DOI : 10.1109/DCC.2008.61
