A compact data structure and parallel algorithms for permutation graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1995
Starting from a permutation of {0,...,n-1} we compute in parallel with a workload of O(n log n) a compact data structure of size O(n log n). This data structure allows to obtain the associated permutation graph and the transitive closure and reduction of the associated order of dimension 2 efficiently. The parallel algorithms obtained have a workload of O(n + m log n) where m is the number of edges of the permutation graph. They run in time O(log^2 n) on a CREW PRAM
wg95.pdf (185.54 Ko) Télécharger le fichier
inria-00471607 , version 1 (08-04-2010)
Jens Gustedt, Michel Morvan, Laurent Viennot. A compact data structure and parallel algorithms for permutation graphs. 21st Workshop on Graph-Theoretic Concepts in computer Science (WG), 1995, Aachen, Germany. pp.372-380, ⟨10.1007/3-540-60618-1⟩. ⟨inria-00471607⟩
60 Consultations
109 Téléchargements
