Multipoint relaying for flooding broadcast messages in mobile wireless networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Laurent Viennot
Anis Laouiti
In this paper we discuss the mechanism of multipoint relays (MPRs) to efficiently do the flooding of broadcast messages in the mobile wireless networks. Multipoint relaying is a technique to reduce the number of redundant re-transmissions while diffusing a broadcast message in the network. We discuss the principle and the functioning of MPRs, and propose a heuristic to select these MPRs in a mobile wireless environment. We also analyze the complexity of this heuristic and prove that the computation of a multipoin- t relay set with minimal size is NP-complete. Finally, we present some simulation results to show the efficiency of multipoint relays.
hicss2001.pdf (224.06 Ko) Télécharger le fichier
inria-00471699 , version 1 (09-04-2010)
  • HAL Id : inria-00471699 , version 1
Amir Qayyum, Laurent Viennot, Anis Laouiti. Multipoint relaying for flooding broadcast messages in mobile wireless networks. 35th Annual Hawaii International Conference on System Sciences (HICSS'2002), Jan 2002, Maui, United States. pp.3866 - 3875. ⟨inria-00471699⟩
218 Consultations
450 Téléchargements
