Computing connected dominated sets with multipoint relays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Ad Hoc & Sensor Wireless Networks Année : 2005
Cédric Adjih
Philippe Jacquet
Laurent Viennot
Multipoint relays offer an optimized way of flooding packets in a radio network. However, this technique requires the last hop knowledge: to decide whether or not a flooding packet is retransmitted, a node needs to know from which node the packet was received. When considering broadcasting at IP level, this information may be difficult to obtain. We thus propose a scheme for computing an optimized connected dominating set from multipoint relays. Proof of correctness and simulations are given for all these broadcasting mechanisms.
mpr-cds.pdf (192.79 Ko) Télécharger le fichier
inria-00471715 , version 1 (08-04-2010)
  • HAL Id : inria-00471715 , version 1
Cédric Adjih, Philippe Jacquet, Laurent Viennot. Computing connected dominated sets with multipoint relays. Ad Hoc & Sensor Wireless Networks, 2005, 1 (1-2), pp.27-39. ⟨inria-00471715⟩
151 Consultations
206 Téléchargements
