Processor Virtualization and Split Compilation for Heterogeneous Multicore Embedded Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Erven Rohou
Embedded multiprocessors have always been heterogeneous, driven by the power-efficiency and compute-density of hardware specialization. We aim to achieve portability and sustained performance of complete applications, leveraging diverse programmable cores. We combine instruction-set virtualization with just-in-time compilation, compiling C, C++ and managed languages to a target-independent intermediate language, maximizing the information flow between compilation steps in a split optimization process.
DAC_2010.pdf (175.81 Ko) Télécharger le fichier
inria-00472274 , version 1 (10-04-2010)
  • HAL Id : inria-00472274 , version 1
Albert Cohen, Erven Rohou. Processor Virtualization and Split Compilation for Heterogeneous Multicore Embedded Systems. 47th Annual Design Automation Conference, Jun 2010, Anaheim, CA, United States. ⟨inria-00472274⟩
278 Consultations
478 Téléchargements
