High order transmission conditions for thin conductive sheets in magneto-quasistatics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2011
We propose transmission conditions of order 1, 2 and 3 approximating the shielding behaviour of thin conducting curved sheets for the magneto-quasistatic eddy current model in 2D. This model reduction applies to sheets whose thicknesses $\eps$ are essentially smaller or at the order of the skin depth. The sheet has itself not to be resolved, only its midline is represented by an interface. The computation is directly in one step with almost no additional cost. We prove the well-posedness w.r.t.~to the small parameter $\eps$ and obtain optimal bound for the modelling error outside the sheet of order $\eps^{N+1}$ for the condition of order N. Numerical experiments with high order finite elements for sheets with varying curvature verify the theoretical findings.
RR-7254.pdf (1.78 Mo) Télécharger le fichier
inria-00473213 , version 1 (14-04-2010)
inria-00473213 , version 2 (24-11-2011)
Kersten Schmidt, Sébastien Tordeux. High order transmission conditions for thin conductive sheets in magneto-quasistatics. ESAIM: Mathematical Modelling and Numerical Analysis, 2011, 45, pp.1115-1140. ⟨10.1051/m2an/2011009⟩. ⟨inria-00473213v1⟩
Collections
ENSTA
291 Consultations
425 Téléchargements
