Existence of optimal control without convexity and a bang-bang theorem for linear volterra equations, Journal of Optimization Theory and Applications, vol.18, issue.1, pp.63-79, 1976. ,
DOI : 10.1007/BF00934052
On the optimal control of systems governed by nonlinear volterra equations, Journal of Optimization Theory and Applications, vol.18, issue.1, pp.29-45, 1976. ,
DOI : 10.1007/BF00934050
Existence Theorems for Hereditary Lagrange and Mayer Problems of Optimal Control, SIAM Journal on Control and Optimization, vol.14, issue.1, pp.1-18, 1976. ,
DOI : 10.1137/0314001
A maximum principle for an optimal control problem with integral constraints, Journal of Optimization Theory and Applications, vol.13, issue.1, pp.32-55, 1974. ,
DOI : 10.1007/BF00935608
Lipschitz solutions of optimal control problems with state constraints of arbitrary order Mathematics and its Applications, Annals of AOSR, vol.2, issue.1, 2010. ,
Well-Posedness of the Shooting Algorithm for State Constrained Optimal Control Problems with a Single Constraint and Control, SIAM Journal on Control and Optimization, vol.46, issue.4, pp.1398-1430, 2007. ,
DOI : 10.1137/06065756X
URL : https://hal.archives-ouvertes.fr/inria-00071379
Stability and sensitivity analysis for optimal control problems with a first-order state constraint and application to continuation methods, ESAIM: Control, Optimisation and Calculus of Variations, vol.14, issue.4, pp.825-863, 2008. ,
DOI : 10.1051/cocv:2008016
No-gap second-order optimality conditions for optimal control problems with a single state constraint and control, Mathematical Programming, vol.32, issue.4, pp.21-50, 2009. ,
DOI : 10.1007/s10107-007-0167-8
URL : https://hal.archives-ouvertes.fr/inria-00070189
Second-order analysis for optimal control problems with pure state constraints and mixed control-state constraints, Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.26, issue.2, pp.561-598, 2009. ,
DOI : 10.1016/j.anihpc.2007.12.002
URL : https://hal.archives-ouvertes.fr/hal-00778357
OPTIMAL PROGRAMMING PROBLEMS WITH INEQUALITY CONSTRAINTS, AIAA Journal, vol.1, issue.11, pp.2544-2550, 1963. ,
DOI : 10.2514/3.2107
On some optimal control problems governed by a state equation with memory, ESAIM: Control, Optimisation and Calculus of Variations, vol.14, issue.4, pp.725-743, 2008. ,
DOI : 10.1051/cocv:2008005
URL : https://hal.archives-ouvertes.fr/hal-00361008
An elementary proof of the maximum principle for optimal control problems governed by a Volterra integral equation, Journal of Optimization Theory and Applications, vol.8, issue.1, 1987. ,
DOI : 10.1007/BF00940404
Necessary conditions for optimal terminal time control problems governed by a Volterra integral equation, J. Optim. Theory Appl, vol.130, issue.1, pp.79-93, 2006. ,
Quadratic conditions for the Pontryagin minimum in an optimal control problem that is linear with respect to control, with a constraint on the control, Dokl. Akad. Nauk SSSR, vol.272, issue.2, pp.285-289, 1983. ,
Lipschitz continuity of optimal control and Lagrange multipliers in a problem with mixed and pure state constraints, 2009. ,
Nonconvex minimization problems, Bulletin of the American Mathematical Society, vol.1, issue.3, pp.443-474, 1979. ,
DOI : 10.1090/S0273-0979-1979-14595-6
Lipschitz Continuity of Optimal Controls for State Constrained Problems, SIAM Journal on Control and Optimization, vol.42, issue.5, pp.1727-1744, 2003. ,
DOI : 10.1137/S0363012902404711
Regularity of optimal controls for state constrained problems, J. Global Optim, vol.28, issue.3-4, pp.305-317, 2004. ,
Lipschitz Continuity for Constrained Processes, SIAM Journal on Control and Optimization, vol.17, issue.3, pp.321-338, 1979. ,
DOI : 10.1137/0317026
Stability Analysis of Optimal Control Problems with a Second-Order State Constraint, SIAM Journal on Optimization, vol.20, issue.1, pp.104-129, 2009. ,
DOI : 10.1137/070707993
URL : https://hal.archives-ouvertes.fr/inria-00186968
Mathematical Modeling in Economics, Ecology, and the Environment, 1999. ,
New necessary conditions of optimality for control problems with state-variable inequality contraints ,
Dynamic Optimization. The calculus of variations and optimal control in economics and management, 1991. ,
Stability Analysis for Nonlinear Optimal Control Problems Subject to State Constraints, SIAM Journal on Optimization, vol.18, issue.3, pp.926-945, 2007. ,
DOI : 10.1137/060661247
Second-order conditions in stability analysis for state constrained optimal control, Journal of Global Optimization, vol.5, issue.1-3, pp.161-168, 2008. ,
DOI : 10.1007/s10898-007-9188-3
On the minimum principle for optimal control problems with state constraints, 1979. ,
Comments on the Paper ???Optimal Control of Processes Described by Integral Equations. I??? by V. R. Vinokurov, SIAM Journal on Control, vol.8, issue.4, p.572, 1970. ,
DOI : 10.1137/0308041
Optimization, 1976. ,
How to state necessary optimality conditions for control problems with deviating arguments? ESAIM Control Optim, Calc. Var, vol.14, issue.2, pp.381-409, 2008. ,
DOI : 10.1051/cocv:2007058
URL : http://archive.numdam.org/article/COCV_2008__14_2_381_0.pdf
Regularity properties of optimal controls for problems with time-varying state and control constraints, Nonlinear Analysis: Theory, Methods & Applications, vol.65, issue.2, pp.448-474, 2006. ,
DOI : 10.1016/j.na.2005.07.041
Optimal Control of Processes Described by Integral Equations. I, SIAM Journal on Control, vol.7, issue.2, pp.324-336, 1969. ,
DOI : 10.1137/0307022
