An exact recursion relation solution for the steady-state surface temperature of a general multilayer structure, IEEE Transactions on Components, Packaging, and Manufacturing Technology: Part A, vol.18, issue.1, pp.31-38, 1995. ,
DOI : 10.1109/95.370732
Three-dimensional transient thermal simulation: application to delayed short circuit protection in power ICs, IEEE Journal of Solid-State Circuits, vol.15, issue.3, pp.15277-281, 1980. ,
DOI : 10.1109/JSSC.1980.1051383
Electrothermal CAD of power devices and circuits with fully physical time-dependent compact thermal modeling of complex nonlinear 3-d systems, IEEE Transactions on Components and Packaging Technologies, vol.24, issue.4, pp.566-590, 2001. ,
DOI : 10.1109/6144.974944
Temperature solution o f five-layer structure with an embedded circular source, [1992 Proceedings] Intersociety Conference on Thermal Phenomena in Electronic Systems, 1992. ,
DOI : 10.1109/ITHERM.1992.187759
Thermal Characterization of Electronic Packages Using a Three-Dimensional Fourier Series Solution, Journal of Electronic Packaging, vol.122, issue.3, pp.233-239, 2000. ,
DOI : 10.1115/1.1287928
Three-dimensional thermal modeling based on the two-port network theory for hybrid or monolithic integrated power circuits, IEEE Transactions on Components, Packaging, and Manufacturing Technology: Part A, vol.19, issue.4, pp.501-507, 1996. ,
DOI : 10.1109/95.554931
The effect of some composite structures on the thermal resistance of substrates and integrated circuit chips, IEEE Transactions on Electron Devices, vol.20, issue.3, pp.20233-238, 1973. ,
DOI : 10.1109/T-ED.1973.17634
The Design and Implementation of FFTW3, Proceedings of the IEEE, pp.216-231, 2005. ,
DOI : 10.1109/JPROC.2004.840301
Spatially-Resolved Imaging of Microprocessor Power (SIMP): Hotspots in Microprocessors, Thermal and Thermomechanical Proceedings 10th Intersociety Conference on Phenomena in Electronics Systems, 2006. ITHERM 2006., 2006. ,
DOI : 10.1109/ITHERM.2006.1645331
Hotspot-Limited Microprocessors: Direct Temperature and Power Distribution Measurements, IEEE Journal of Solid-State Circuits, vol.42, issue.1, pp.56-65, 2007. ,
DOI : 10.1109/JSSC.2006.885064
Thermal analysis of multiple-layer structures, IEEE Transactions on Electron Devices, vol.21, issue.11, pp.674-681, 1974. ,
DOI : 10.1109/T-ED.1974.17993
An integration algorithm for the temperature solution of the four-layer infinite plate structure, Fifth Annual IEEE Semiconductor Thermal and Temperature Measurement Symposium, 1989. ,
DOI : 10.1109/STHERM.1989.76065
A new approach to thermal analysis of power devices, IEEE Transactions on Electron Devices, vol.34, issue.5, pp.341147-1156, 1987. ,
DOI : 10.1109/T-ED.1987.23057
Thermal quadrupoles -Solving the heat equation through integral transforms, 2000. ,
Transient thermal study of semiconductor devices, Proceedings of the 6th SEMI-THERM Symposium, 1990. ,
Boundary value problems of heat conduction, 1968. ,
Generalized image method with application to the thermal modeling of power devices and circuits, IEEE Transactions on Electron Devices, vol.49, issue.4, pp.679-686, 2002. ,
DOI : 10.1109/16.992879
Fast thermal analysis for VLSI circuits via semi-analytical Green's function in multi-layer materials, Proceedings of the International Symposium on Circuits and Systems, 2004. ,
Accelerated Chip-Level Thermal Analysis Using Multilayer Green's Function, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.26, issue.2, pp.325-344, 2007. ,
DOI : 10.1109/TCAD.2006.883919
Thermal modeling of a small extreme power density macro on a high power density microprocessor chip in the presence of realistic packaging and interconnect structures, Proceedings of the Electronic Components and Technology Conference, 2004. ,
Generalized thermal analysis of hotspots on a high power density microprocessor chip, Proceedings of the Electronic Components and Technology Conference, 2005. ,
Fast computation of the temperature distribution in VLSI chips using the discrete cosine transform and table look-up, Proceedings of the 2005 conference on Asia South Pacific design automation , ASP-DAC '05, 2005. ,
DOI : 10.1145/1120725.1120753
A high efficiency full-chip thermal simulation algorithm, Proceedings of the International Conference on Computer-Aided Design, 2005. ,
