On implementing omega with weak reliability and synchrony assumptions, PODCAH93] Efthymios Anagnostou and Vassos Hadzilacos. Tolerating transient and permanent failures WDAG, pp.306-314, 1993. ,
Fault-tolerance and self-stabilization: impossibility results and solutions using self-stabilizing failure detectors, International Journal of Systems Science, vol.32, issue.11, pp.1177-1187, 1997. ,
DOI : 10.1007/BFb0020419
The weakest failure detector for solving consensus, Journal of the ACM, vol.43, issue.4, pp.685-722, 1996. ,
DOI : 10.1145/234533.234549
Stéphane Devismes, and Hugues Fauconnier. Robust stabilizing leader election, SSS, pp.219-233, 2007. ,
Self-stabilizing systems in spite of distributed control, Communications of the ACM, vol.17, issue.11, pp.643-644, 1974. ,
DOI : 10.1145/361179.361202
Unifying self-stabilization and fault-tolerance (preliminary version), PODC, pp.195-206, 1993. ,
Optimal implementation of the weakest failure detector for solving consensus, Proceedings 19th IEEE Symposium on Reliable Distributed Systems SRDS-2000, pp.52-59, 2000. ,
DOI : 10.1109/RELDI.2000.885392
