Biais dans les mesures obtenues par un réseau de capteurs sans fil
In the area of complex networks, research has been stimulated by the availability of important data sets obtained through automatic measurement. In this article, we focus on interaction data in a hospital, gathered through the use of a wireless sensor network. We highlight the bias introduced by the measurement system and propose a method to reconstruct the original signal which evidences phenomenon which were not visible on the raw data.
