Conference papers
Domain-specific Model Editors with Model Completion
Sagar Sen 1 Benoit Baudry 1 Hans Vangheluwe 1
1 TRISKELL - Reliable and efficient component based software engineering
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : Today, integrated development environments such as Eclipse allow users to write programs quickly by presenting a set of recommendations for code completion. Similarly, word processing tools such as Microsoft Word present corrections for grammatical errors in sentences. Both of these existing systems use a set of constraints expressed in the form of a grammar to restrict/correct the user. Taking this idea further, in this paper we present an integrated software system capable of generating recommendations for model completion of partial models built in arbitrary domain speciÞc model editors. We synthesize the model editor equipped with automatic completion from a modelling language's declarative speciÞcation consisting of a meta-model and constraints on it along with a visual syntax. The automatic completion feature is powered by a Prolog engine whose input is a constraint logic program derived from some models. The input logic program is obtained by a model transformation from models in multiple languages: the meta-model (as a class diagram), constraints on it (as constraint logic clauses), and a partial model (in the domain speciÞc language). The Prolog engine solves the generated logic program and the solution(if there is one) is returned to the model editor as a set of recommendations for properties of the partial model. We incorporate automatic completion in the generative tool AToM 3 and use SWI-Prolog for constraint representation and satisfaction. We present examples using an illustrative visual language of Finite State Machines.
Document type :
Conference papers
Complete list of metadata
Cited literature [4 references]  Display  Hide  Download
https://hal.inria.fr/inria-00477554
Contributor : Didier Vojtisek Connect in order to contact the contributor
Submitted on : Thursday, April 29, 2010 - 3:09:22 PM
Last modification on : Tuesday, June 15, 2021 - 4:16:13 PM
Long-term archiving on: : Wednesday, November 30, 2016 - 5:20:57 PM
File
sen07a.pdf
Identifiers
  • HAL Id : inria-00477554, version 1
Citation
Sagar Sen, Benoit Baudry, Hans Vangheluwe. Domain-specific Model Editors with Model Completion. In Proceedings of MPM Workshop associated to MoDELS'07, 2007, Nashville, TN, USA, United States. ⟨inria-00477554⟩
Share
Metrics
Les métriques sont temporairement indisponibles
