Speech enhancement using harmonic regeneration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This paper addresses the problem of single microphone speech enhancement in noisy environments. Common short-time noise reduction techniques introduce harmonic distortion in enhanced speech because of the non reliability of estimators for small signal-to-noise ratios. We propose a new method called Harmonic Regeneration Noise Reduction technique which solves this problem. A fully harmonic signal is calculated based on the distorted signal using a non-linearity to regenerate harmonics in an efficient way. This artificial signal is then used to compute a suppression gain able to preserve the speech harmonics. This method is theoretically analyzed, then objective and formal subjective results are given and show a significant improvement compared to classical noise reduction techniques.
ICASSP055.pdf (401.58 Ko) Télécharger le fichier
inria-00482692 , version 1 (11-05-2010)
  • HAL Id : inria-00482692 , version 1
Cyril Plapous, Claude Marro, Pascal Scalart. Speech enhancement using harmonic regeneration. IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP'2005), Mar 2005, Philadelphia, United States. ⟨inria-00482692⟩
438 Consultations
1054 Téléchargements
