Reports
Un profil UML pour la modélisation multiniveau
Frédéric Mallet 1 Charles André 1 François Lagarde 2
1 AOSTE - Models and methods of analysis and optimization for systems with real-time and embedding constraints
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Paris-Rocquencourt, Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : Building a UML profile is tedious and error-prone. There is no precise methodology to guide the process. Best practices recommend gathering concepts in a technology-independent domain view before implementation. Still, the adequacy of the implementation should be verified. This paper proposes to transform automatically a domain model into a profile-based implementation. To reduce accidental complexity in the domain model and fully benefit from advanced profiling features in the generated profile, our process relies on the multilevel paradigm. The value of this paradigm for the definition of UML profiles is assessed and applied to a subset of the MARTE time model.
Document type :
Reports
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/inria-00482727
Contributor : Frédéric Mallet Connect in order to contact the contributor
Submitted on : Tuesday, May 11, 2010 - 12:08:30 PM
Last modification on : Tuesday, January 11, 2022 - 11:16:21 AM
Long-term archiving on: : Thursday, September 16, 2010 - 2:03:36 PM
File
RR-7287.pdf
Identifiers
  • HAL Id : inria-00482727, version 1
Collections
Citation
Frédéric Mallet, Charles André, François Lagarde. Un profil UML pour la modélisation multiniveau. [Rapport de recherche] RR-7287, INRIA. 2010. ⟨inria-00482727⟩
Share
Metrics
Les métriques sont temporairement indisponibles
