Automatic sqnr determination in non-linear and non-recursive fixed-point systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Most of the digital signal processing applications are implemented in embedded systems which are based on fixed-point arithmetic. The reduction of the time-to-market requires the automation of the fixed-point specification determination. The accuracy evaluation is one of the most important stage of this process. In this paper, a new methodology for evaluating the quality of non-recursive and non-linear systems is presented. The fixed-point specification accuracy is automatically determined through the computation of the Signal-to-Quantization-Noise-Ratio (SQNR) expression. The theoretical approach used for computing the output noise power is detailed and the methodology developed for automating the accuracy evaluation is presented. Then, the quality of our estimation is evaluated through different experiments.
Fichier non déposé
inria-00482941 , version 1 (12-05-2010)
  • HAL Id : inria-00482941 , version 1
Daniel Menard, Romuald Rocher, Pascal Scalart, Olivier Sentieys. Automatic sqnr determination in non-linear and non-recursive fixed-point systems. XII. European Signal Processing Conference (EUSIPCO 2004), Sep 2004, Vienna, Austria. ⟨inria-00482941⟩
169 Consultations
0 Téléchargements
