Interactive and descriptor-based deployment of object-oriented grid applications, Proceedings 11th IEEE International Symposium on High Performance Distributed Computing, pp.93-102, 2002. ,
DOI : 10.1109/HPDC.2002.1029907
Hierarchical and Declarative Security for Grid Applications, 10th International Conference On High Performance Computing, HIPC, pp.363-372, 2003. ,
DOI : 10.1007/978-3-540-24596-4_39
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.3.7713
Efficient, flexible, and typed group communications in Java, Proceedings of the 2002 joint ACM-ISCOPE conference on Java Grande , JGI '02, pp.28-36, 2002. ,
DOI : 10.1145/583810.583814
From Distributed Objects to Hierarchical Grid Components, CoopIS, DOA, and ODBASE -OTM Confederated International Conferences, CoopIS, DOA, and ODBASE 2003, pp.1226-1242, 2003. ,
DOI : 10.1007/978-3-540-39964-3_78
Recursive and dynamic software composition with sharing, Proceedings of the 7th ECOOP International Workshop on Component-Oriented Programming, 2002. ,
Fractal web site, 2003. ,
Overview of Grid Computing Environments. Global Grid Forum document, 2003. ,
The Legion Vision of a World-wide Virtual Computer, Communications of the ACM, vol.40, 1997. ,
From Legion to Legion-G to OGSI.NET: object-based computing for Grids, Proceedings International Parallel and Distributed Processing Symposium, 2003. ,
DOI : 10.1109/IPDPS.2003.1213379
A component based services architecture for building distributed applications, Proceedings the Ninth International Symposium on High-Performance Distributed Computing, 2000. ,
DOI : 10.1109/HPDC.2000.868634
Achieving portable and efficient parallel CORBA objects, Concurrency and Computation: Practice and Experience, vol.23, issue.11, pp.891-909, 2003. ,
DOI : 10.1002/cpe.738
URL : https://hal.archives-ouvertes.fr/inria-00411025
Padico: a component-based software infrastructure for Grid computing, Proceedings International Parallel and Distributed Processing Symposium, 2003. ,
DOI : 10.1109/IPDPS.2003.1213073
URL : https://hal.archives-ouvertes.fr/inria-00071604
The C++// Language In: Parallel Programming using C++, pp.257-296, 1996. ,
Distributed objects for parallel numerical applications. Mathematical Modelling and Numerical Analysis Modelisation, special issue on Programming tools for Numerical Analysis, pp.36-837, 2002. ,
Benchmarking Java against C and Fortran for Scientific Applications, In: Joint ACM Java Grande -ISCOPE, 2001. ,
Toward a method of object-oriented concurrent programming, Communications of the ACM, vol.36, issue.9, pp.90-102, 1993. ,
DOI : 10.1145/162685.162711
Implementing references as chains of links, [1992] Proceedings of the Second International Workshop on Object Orientation in Operating Systems, 1992. ,
DOI : 10.1109/IWOOOS.1992.252975
URL : https://hal.archives-ouvertes.fr/inria-00444623
Ubiquitous message passing interface implementation in Java: JMPI, Proc. 13th Int. Parallel Processing Symp. and 10th Symp. on Parallel and Distributed Processing, 1999. ,
A parallel object-oriented application for 3D electromagnetism, 18th International Parallel and Distributed Processing Symposium, 2004. Proceedings., 2004. ,
DOI : 10.1109/IPDPS.2004.1302908
A fault tolerant mpi for volatile nodes based on the pessimistic sender based message logging, ACM/IEEE International Conference on Supercomputing SC 2003, 2003. ,
Wrapping MPI-based legacy codes as Java/CORBA components, Future Generation Computer Systems, vol.18, issue.2, pp.213-223, 2001. ,
DOI : 10.1016/S0167-739X(00)00093-5
A Collaborative Code Development Environment for Computational Electro-Magnetics, IFIP TC2/WG2.5 Working Conference on the Architecture of Scientific Software, pp.119-141, 2001. ,
DOI : 10.1007/978-0-387-35407-1_8
