Reports
Deterministic Recurrent Communication in Restricted Sensor Networks
Abstract : In Sensor Networks, the lack of topology information and the availability of only one communication channel has led research work to the use of randomization to deal with collisions of transmissions. However, the scarcest resource in this setting is the energy supply, and radio communication dominates the sensor node energy consumption. Hence, redundant trials of transmission as used in randomized protocols may be counter-effective. Additionally, most of the research work in Sensor Networks is either heuristic or includes unrealistic assumptions. Hence, provable results for many basic problems still remain to be given. In this paper, we study upper and lower bounds for deterministic communication primitives under the harsh constraints of sensor nodes.
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/inria-00486270
Contributor : Chrsitopher Thraves Caro Connect in order to contact the contributor
Submitted on : Wednesday, May 26, 2010 - 12:44:05 PM
Last modification on : Thursday, January 20, 2022 - 4:20:15 PM
Long-term archiving on: : Thursday, December 1, 2016 - 2:39:58 PM
File
Research-reaport.pdf
Identifiers
  • HAL Id : inria-00486270, version 2
Citation
Antonio Fernández Anta, Miguel Mosteiro, Christopher Thraves-Caro. Deterministic Recurrent Communication in Restricted Sensor Networks. [Research Report] 2010. ⟨inria-00486270v2⟩
Share
Metrics
Record views
132
Files downloads
252
