A Three Level Framework for Adapting Component-Based Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This paper deals with the issue of software adaptation. We focus on Component-Based Software Development including Architecture Description Languages, and clearly identify three levels of adaptation. We argue that capturing functional and non-functional changes in a system requires various types of adaptation tools working at different granularities and times in the system lifecycle, with various actors.
ecoopwcat05.pdf (124.08 Ko) Télécharger le fichier
inria-00486734 , version 1 (26-05-2010)
  • HAL Id : inria-00486734 , version 1
Nicolas Pessemier, Olivier Barais, Lionel Seinturier, Thierry Coupaye, Laurence Duchien. A Three Level Framework for Adapting Component-Based Systems. 2nd Workshop on Coordination and Adaptation Techniques for Software Entities (WCAT) at the 19th European Conference on Object-Oriented Programming (ECOOP'05), Jul 2005, Glasgow, United Kingdom. ⟨inria-00486734⟩
187 Consultations
304 Téléchargements
