Integrating Mode Automata Control Models in SoC Co-Design for Dynamically Reconfigurable FPGAs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The number of integrated transistors that can be contained on a chip are increasing at an exponential rate, along with rise in targeted sophisticated applications. Thus the design of Systems-on-Chip (SoC) is becoming more and more complex. Hence there is a critical need to find new seamless methodologies and tools to handle the SoC co-design aspects. This paper presents a novel approach for expressing system adaptivity and reconfigurability in Gaspard, a SoC co-design framework, with special focus on partially dynamically reconfigurable FPGAs. The framework is compliant with UML MARTE profile proposed by Object Management Group, for modeling and analysis of realtime embedded systems. The overall objective is to carry out system modeling at a high abstraction level expressed in UML; and afterwards, transform these high level models into detailed enriched lower level models in order to automatically generate the necessary code for final FPGA synthesis
dasip09_irq_paper.pdf (839.55 Ko) Télécharger le fichier
inria-00486919 , version 1 (27-05-2010)
  • HAL Id : inria-00486919 , version 1
Imran Rafiq Quadri, Samy Meftali, Jean-Luc Dekeyser. Integrating Mode Automata Control Models in SoC Co-Design for Dynamically Reconfigurable FPGAs. International Conference on Design and Architectures for Signal and Image Processing (DASIP 09), Sep 2009, Nice, France. ⟨inria-00486919⟩
353 Consultations
153 Téléchargements
